Nokia E61 registration
Feb 18th, 2008
Hi to all,
I have a CCME 4.2 and a Nokia E61 with installed Intellisysnc 1.1, a access point 1200.
I'm trying to configure the E61 to connect as IPphone, on wireless are correct associated (it browes intenet, e-mail etc) the SCCP client is correct configured (it seems... I also configure TFTP manually as CCME ip), but when I try to do a call with "internet telphony" it try to register on CCME but after some minute goes in timeout.
Here the configuration on the ephone on CCME:
telephony-service
load 7960-7940 P00308000500
load 7920 cmterm_7920.4.0-03-02
load 7941 SCCP41.8-2-2SR2S
load 7961 SCCP41.8-2-2SR2S
load 7971 SCCP70.8-2-2SR4S
load 7970 SCCP70.8-2-2SR4S
ephone-dn 17 dual-line
number 1017
description Nokia E61 Neri
name Nokia E61 Neri
no huntstop
ephone 21
device-security-mode none
mac-address 0013.FD43.61CB
type 7970
button 1:17
I'm sure of mac-address becasue I check it on AP and I read it on phone.
CCME can ping E61.
What can I check to verify why e61 does not registering? Any Ideas?
Thank
Augusto
a.crippa Mon, 02/18/2008 - 09:10
OK I already resolved, I restart the procedure of activation of intellisync ICC, that it seem was not correct licensed!
Now works fine.
Augusto.
Paolo Bevilacqua Mon, 02/18/2008 - 10:11
  • Hall of Fame,
    Founding Member
All good...
Beware that using 8.0 the 7940 can go mute at random ... downgrade to 7.2.T023 if it happens.
