How to disable Unity for accetping new voicemails
Feb 18th, 2008
I will be doing a migration to failover on new servers over the weekend.
I will be using DiRT to backup and restore data and messages. I am concerned that some important messages left during this time may be lost in a "no mans land", so I want to disable unity from accepting new messages.
I would like to keep unity on line for call handlers,so I cannot shut it down completely. I just want to disable any new messages being recieved.
Overall Rating: 5 (1 ratings)
Adam Thompson Wed, 02/20/2008 - 10:42
  • Silver, 250 points or more
Without more detail on how you have Unity set up for handling the incoming calls, I can't comment directly. However, I will offer a suggestion based on how our system is set up.
If I were going to try and disallow incoming calls I would change the 'Call Routing/Forwarded Calls' profile that I have for incoming calls to go to a call handler that played a message stating that no new VM calls are being accepted at this time, and then drop the call. (You may need to repeat this in the Call Routing/Direct Calls section also)
Since you said that you need the existing call handlers to still work, just place the Call Routing rules for those call handlers higher in the list.
I can provide more detail and possibly some screen shots if you need them.
Please rate this post if it helps.
-Adam
hauchinango Wed, 02/20/2008 - 11:19
Adam,
thanks for the info...great idea.
I will do something similar to fit the my config.
