Cat 500 24LC and which 4 ports are POE
I must be having a thick moment. Are all the ports on the 24LC capable of POE but the limitation is that the switch can only support 4 ports due to power max at 60w?
Also, is the way to set POE on a port to set the port to an Access Point? The whole Smartport concept is very limiting.
I want to run IP Camera's on POE, but can't seem to find any reference to how to set a port to POE other that as an AP.
Any points would be appreciated.
aijaz802 Mon, 02/18/2008 - 22:40
AFAIK there is no need to configure the power settings, it will auto detect. You need to specify the port type as AP while configuring the switch. The AP & IP camera power settings will be same.
You can go thru the following links for configuring the smartport types.
I hope it helps...pls rate if it solves ur issue.
