ASA + Allow VPN users Access to networked resources
Feb 18th, 2008
Hello All,
I am attempting to allow remote vpn users access to a "shared drive" but I am running into problems. I have established the following:
1) A successfull VPN connection
2) VPN users get IP addresses in the following range: 192.168.1.0/24
When I attempt to allow the users access to the internal network which is on the 10.88.0.0 subnet, it errors out.
However, I am able to succesfully get out to the Internet after I VPN into my network but I JUST CANNOT access the shared drive.
The following information might be relavent:
ASA version 7.7(2)
On Static NAT for the Domain Controller
Internal: 10.88.0.2
External: 12.x.x.x
Firewall
Internel: 10.88.0.4
External: 12.x.x.x.
I have also attached a screen shot of the "Packet Trace" I performed. The error says it is a NATing issue. Any help would be appriciated. Thanks.
acomiskey Mon, 02/18/2008 - 11:10
  • Green, 3000 points or more
Could you post the config?
cisco24x7 Mon, 02/18/2008 - 11:20
  • Silver, 250 points or more
access-list nonat permit ip 10.88.0.0/24 192.168.1.0/24
nat (inside) 0 access-list nonat
isakmp nat-t 10
Your vpn will work after that.
CCIE Security
najeebsyed2 Mon, 02/18/2008 - 13:09
Thank you very much. It worked !! Can you explain this command? I know it created a NAT exemption but I am clueless as to what it exactly means. Thanks !!!
