WIC-1DSU-T1-V2 not showing up as Interface S1/0 on 2610
Feb 18th, 2008
We have a Cisco 2610 router which only handles one T1 right now. We wanted to add a second T1. So we got a new card WIC-1DSU-T1-V2 and plugged that in W1 slot.
When I run show diag I can see the card but it does not appear on the running configuration.
The other card: WIC-1DSU-T1 right now it is working just fine.
How can I use the WIC-1DSU-T1-V2 on this router?
Here it is what I get
gw#show version
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.3(5f), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 12-Aug-05 13:29 by ssearch
Image text-base: 0x80008098, data-base: 0x80D239EC
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
gw uptime is 1 hour, 24 minutes
System returned to ROM by reload
System restarted at 12:33:13 EST Mon Feb 18 2008
System image file is "flash:c2600-io3-mz.123-5f.bin"
cisco 2610 (MPC860) processor (revision 0x202) with 61440K/4096K bytes of memory
Processor board ID JAB032000AT (601560906)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
gw#show diag
Slot 0:
C2610 1E Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 2.2
PCB Serial Number : JAB032000AT (601560906)
Part Number : 73-2839-12
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
WIC Slot 0:
FT1 BT8360
Hardware revision 1.3 Board revision C0
Serial number 16814057 Part number 800-03279-03
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
0x20: 02 11 01 03 01 00 8F E9 50 0C CF 03 00 00 00 00
0x30: 60 00 00 00 99 10 29 01 FF FF FF FF FF FF FF FF
WIC Slot 1:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC11491PSV
Part Number : 73-8346-05
Board Revision : A0
RMA Test History : 00
RMA History : 00
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
Slot 1:
Ethernet Port adapter, 1 port
Hardware revision 1.1 Board revision F0
Serial number 27264352 Part number 800-02026-03
FRU Part Number: NM-1E=
EEPROM format version 1
gw#show running-conf
interface Ethernet0/0
half-duplex
no keepalive
interface Serial0/0
ip address 64.148.137.78 255.255.255.252
ip access-group 105 in
fair-queue 64 256 0
service-module t1 timeslots 1-23
interface Ethernet1/0
description "Connected to Internal LAN"
ip address 10.10.10.1 255.255.255.0
half-duplex
no keepalive
shivlu jain Tue, 02/19/2008 - 01:41
this can be the IOS issue try to switch over to another ios
regards
shivlu
Richard Burts Tue, 02/19/2008 - 04:47
Gentian has posted this same question on the LAN Switching and Routing forum where it has generated quite a few responses (which include both suggestions made here). I suggest that any further discussion of this question be consolidated in the LAN forum.
Rick
gentianhila Tue, 02/19/2008 - 06:12
That is right. I thought WAN it would be a more appropriate place than LAN to post such a question.
