inter Vlan routing
Answered Question
Feb 18th, 2008
Hi, I have a layer 3 switch and I want to add a new VLAN to the switch. Howerver when I put in the new VLAN it doesn't show up as a directly connected network in the output of "show ip route"
I did not shut on the VLAN interface. When I do "show ip int brief" the interface is up but the Protocol is down. I do not know why this is. My guess is that the "ip default gateway" command is stopping the vlan from being entered as a directly connected network. I do have ip routing turned on. Can anyone tell me what I am missing? Thanks for the help!!!!!!
show ip int brief
Vlan1 172.24.1.3 YES NVRAM up up
Vlan25 172.25.1.2 YES manual up down
Vlan26 172.26.1.2 YES manual up down
show ip route
Gateway of last resort is 172.24.1.1 to network 0.0.0.0
172.21.0.0/24 is subnetted, 1 subnets
S 172.21.19.0 [1/0] via 172.24.1.2
S 172.23.0.0/16 [1/0] via 172.24.1.2
172.22.0.0/24 is subnetted, 1 subnets
S 172.22.19.0 [1/0] via 172.24.1.2
172.24.0.0/24 is subnetted, 1 subnets
C 172.24.1.0 is directly connected, Vlan1
S* 0.0.0.0/0 [1/0] via 172.24.1.1
show vlan
1 enet 100001 1500 - - - - - 0 0
25 enet 100025 1500 - - - - - 0 0
26 enet 100026 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
show run
ip default-gateway 172.24.1.2
ip classless
ip route 0.0.0.0 0.0.0.0 172.24.1.1
ip route 172.21.19.0 255.255.255.0 172.24.1.2
ip route 172.22.19.0 255.255.255.0 172.24.1.2
ip route 172.23.0.0 255.255.0.0 172.24.1.2
ip route 172.26.1.0 255.255.255.0 Vlan26
ip http server
interface Vlan1
ip address 172.24.1.3 255.255.255.0
ip directed-broadcast
no ip route-cache
interface Vlan25
ip address 172.25.1.2 255.255.255.0
interface Vlan26
ip address 172.26.1.2 255.255.255.0
Correct Answer by Jon Marshall about 9 years 6 days ago
No you still have ip routing as you also have a default route in your config ie.
If you do inter-vlan routing on the switch then you do not need the connection to the router to be a trunk port. As you say it only needs to be a trunk if you are doing routing on a stick. You should either
i) make the interface an access port and assign it into one of the vlans on the switch
ii) On the interface on the switch make it a routed connection ie "no switch port" and then use a /30 subnet to connect the router to your L3 switch.
Hope this makes sense
Jon
Okay a number of things
1) Remove the "ip default-gateway 172.24.1.2" in your config. That is for when you do not have ip routing enabled.
2) If the vlan interfaces are down then do you have either
i) any trunk links configured on this switch. A trunk link that allows vlans 25 & 26 will bring those interfaces up.
or
ii) if you don't have a trunk you need at least one port in each vlan to bring that vlan interface up.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Mon, 02/18/2008 - 12:43
or
Jon
bsudol79p Mon, 02/18/2008 - 12:49
Thanks that is what I suspected, but in the show run it says "ip rotuting" so I thought that it is still turned on. I just have one switch at that location that is connected to the router. If I do inter vlan routing, does the connection between the switch and router have to be a trunk port? Or does that only pertain to router on a stick? Thanks
Correct Answer
Jon Marshall Mon, 02/18/2008 - 12:53
Jon
vincent-n Mon, 02/18/2008 - 18:38
A small suggestion from me:
1. I noticed that you're using vlan1 interface to reach default gateway 172.24.1.2. Suggesting that you should try to avoid using VLAN1 for routing/L2 switching but instead use it purely for management purposes.
2. If vlan 172.24.1.0 is a data vlan then create a vlan24 interface instead.
3. You don't have to trunk your router on a stick. Use your switch as L3 vlan routing and have your router connected to say vlan24 (172.24.1.2) on a switch port (int F1/0/1; switch acc vlan 24);
4. configure default route ip route 0.0.0.0 0.0.0.0 172.24.1.2 and get rid of ip default-gateway 172.24.1.2 command
