ACS Windows Agent Issue
Answered Question
We just upgraded our 3.3. ACS to the latest version without issue. I created the Remote Agent on the ACS, but we I install the Agent on the Windows 2003 server I get "Unable to initialize variables". Anyone? Thanks.
John
Correct Answer by somishra about 8 years 11 months ago
John,
- Logon to the computer as a Local Administrator, preferably "Administrator", and then try and uninstall Remote Agent & try and install it back. Log on locally to the box and install the RA.
- If above doesn't work, you might have to manually uninstall Remote Agent. After uninstalling, you can try to reinstall the current version of the remote agent.
somishra
Overall Rating: 5 (1 ratings)
Correct Answer
somishra Mon, 02/18/2008 - 13:27
John,
somishra
