ERROR: Bad mask 255.255.255.0 for address 10.96.1.0
Answered Question
Feb 18th, 2008
Hi, I have a ASA 5505 when i want to assign an ip address to for example vlan 2 like 10.96.1.0 255.255.255.0 it gives me the above error.
please help
Correct Answer by elparis about 8 years 11 months ago
10.96.1.0 is the network address if you are using 255.255.255.0 as the network mask, so you can't use that address for your device. The first available address in 10.96.1.0/24 is 10.96.1.1. You can use that one.
Overall Rating: 5 (1 ratings)
Correct Answer
elparis Mon, 02/18/2008 - 15:54
rouzbehta Mon, 02/18/2008 - 15:57
ohhhhh, Thank You so much ,I forgot this,yes it accepted , Thank you and Thank you.
Rouzbeh.
