" ip load-sharing per-packet " 3750
Feb 18th, 2008
It seems you cannot enter " ip load-sharing per-packet " on a layer 3 Vlan interface on a 3750. Is this correct and if so, is there a way to configure load sharing on a per packet basis with EIGRP on a 3750?
Overall Rating: 5 (1 ratings)
1.To enable per packet load balancing for all IP traffic, enter the ip load-sharing per-packet command in interface configuration mode and enter the epc xpif-ip-per-pack-all global configuration.
2.To enable per packet load balancing for TCP traffic only, enter the ip load-sharing per-packet command in interface configuration mode and ensure the epc xpif-ip-per-pack-all global configuration command is not entered.
Make sure you are running minimum 12.1(10)E
steve20 Mon, 02/25/2008 - 05:50
Neither command seems to be a valid command on a 3750 with 12.2(25)SEE2.
Edison Ortiz Mon, 02/25/2008 - 06:30
  • Hall of Fame,
    Founding Member
Steve,
You are correct, that command isn't supported in these switches:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_40_se/configuration/guide/swuncli.html#wp1060469
If you want to load-balance per-packet, you must configure Layer2 or Layer3 etherchanneling.
HTH,
__
Edison.
