missed call log
Feb 18th, 2008
I would like to know to ask if 7960 IP phone configure 2 lines, e.g. Line 1 is 4000 and Line 2 is 4001, then can I know from Missed Call Log that how many x4000 missed call and how many x4001 missed call?
somishra Tue, 02/19/2008 - 04:47
Hi Mike,
You would have to manually check for the called number for each missed call to find out which extension has got how many missed calls.
Ex- If you have 2 missed calls, you would have to go to each missed call >> More >> Details.
You would get the called number and the calling number and the time.
hth
somishra
redrobish Wed, 03/05/2008 - 17:08
How about how to get a report for all the missed calls with the above scenario? can someone tell how? i.e. by sql, ART,...etc.
tia
iptuser55 Mon, 03/10/2008 - 03:21
If you run cucm 5.x then you can see the different lines via the more key once you press the missed calls
