rollover cable and cross over cable
Answered Question
Feb 18th, 2008
If I have OOB coonection from a terminal server to a router's console port, do I need to use rollover cable? how about if there's a patch panel betwn terminal server and the router, what cable should I use?
Correct Answer by scottmac about 9 years 3 months ago
Start simple: if it was a term server and a router (via console), the octal serial cable goes directly into the console port of 2500, 2600 ... anything with an RJ45-style port..
If the console is something like a 6500 or 7500, then you'd need an adapter to a db25 connector.
If you were going directly from a PC (db9f)to an RJ45-style console, it's via a "rolled" cable (reverse the pin order, 1-8, 2-7,3-6, etc) which is most often a powder blue flat cable.
Now, if you need to extend those connections, anything that ultimately results in a "straight through" extension should work, if it's not too long.
So, whatever cable you'd normally use, with whatever "straight-through" assemblies you use to create an extension.
Good Luck
Scott
Overall Rating: 5 (1 ratings)
Correct Answer
scottmac Mon, 02/18/2008 - 21:44
  • Green, 3000 points or more
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
