Warning message
Strange Script Error (cisco.com.dialog.PlayPromptDialog is not supported)
Feb 18th, 2008
Hi:
I changed the aa.aef script (included in the CRS) as follow:
Start
Accept(--Triggering Contact)
PlayPrompt (--Triggering Contact, welcomePrompt)
callContact = PlaceCall(to "4041)
[successful branch]
PlayPrompt (callContact, welcomePrompt)
I debug the script in reactive mode and execute it step by step.
The first PlayPrompt and the call to 4041 execute without problem. But when I try to PlayPrompt on the callContact the following error occurs:
The strange is that I can send DTMF tones to the callContact (SendDigits step), but when I try to use PlayPrompt or GetDigits steps on the callContact it fails.
Any clues?
thanks in advance,
marcelo
BCOLE2007 Tue, 02/19/2008 - 10:57
  • Bronze, 100 points or more
What does properties in your Call Contact Step look like?
Marcelo-Rocha Tue, 02/19/2008 - 15:34
callContact is a variable of type Call Contact. The Place Call step has the following properties:
Destination = "4010"
Timeout = 10
Call Control Group ID = 1
Call Contact = callContact (variable to place the call)
Actually, the Place Call take effect (the 4010 terminal rings), but when I pick up the phone and the next step execute (PlayPrompt) there it fires the error:
"com.cisco.dialog.PlayPromptDialog is not supported". I must to note that the PlayPrompt step execute to the outbound call (4010) is the same I executed first in trigger contact. The first executes well but the secont (outbound call) fails.
BCOLE2007 Tue, 02/19/2008 - 15:51
Did you add an ID for a Dialogue group?
BCOLE2007 Tue, 02/19/2008 - 18:09
I am able to recreate this error message in Reactive debug. When I remove the ID in the Dialogue Group, the script will validate , but it seems to be required when doing voice,
I seem to remember a send DTMF will work without the dialogue group though....
please let me know how it goes
Marcelo-Rocha Wed, 02/20/2008 - 12:43
That's right, I did not set the dialog group. I'm going to test it on friday and post a comment.
Yes, I can send DTMF without set that parameter but both steps (PlayPrompt and GetDigits) fail. Both use PlayPrompt.
thank you for your support.
Marcelo
Marcelo-Rocha Thu, 02/21/2008 - 15:16
OK, I test it including a Dialog Group and it works without any problem.
BCOLE2007 Fri, 02/22/2008 - 04:57
Cool glad it works
I would really appreciate it if you could rate this help?
thanks
