multiple login
Feb 18th, 2008
from the access server, is it possible to have multiple reverse telnet sessions to a device?
Overall Rating: 5 (1 ratings)
Richard Burts Mon, 02/18/2008 - 20:27
The reverse telnet from an access server is usually to the console port. I believe that you could also have a reverse telnet connection to the aux port. So I believe that it is possible to have 2 reverse telnet sessions from an access server to a single device. I do not see how you would have any more than 2.
network27 Mon, 02/18/2008 - 23:43
Hi Rick,
Thanks for your reply.
I need it for instructor/students remote access scenarios
Great idea, ill try aux access.Any other ways? Ive tried configuring using differnt port to the same device but it did not work.
