Memory slots on a Cisco 2651XM
Feb 18th, 2008
Hi all
I'd like to find out how many DRAM memory slots are there on a Cisco 2651XM router and whether they're occupied by a memory module or not. Is there a command available that can do this? I currently have 128MB RAM on this router and is looking at upgrading it to 256MB. Thanks.
Overall Rating: 5 (1 ratings)
glen.grant Mon, 02/18/2008 - 18:23
  • Purple, 4500 points or more
Not that I know of , you would have to open up the box.
vaisharm Mon, 02/18/2008 - 19:35
  • Cisco Employee,
Yes, you can use show c2600 command. The following url answers your question:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_field_notice09186a00803acb4c.shtml
You might need this aswell later:
Upgrading System Memory, Internal Flash, and Boot ROM in Cisco 2600 Series Routers
http://www.cisco.com/en/US/docs/routers/access/2600/hardware/installation/notes/2600mem.html#wp92662
-Vaibhav
JORGE RODRIGUEZ Mon, 02/18/2008 - 20:27
  • Green, 3000 points or more
And you are correct,good link info Vaibhav! 5 Pt, this command seems to also apply to 3600 series for mem specs.
