vic2-2fxo not supported in 2811?
Answered Question
Feb 18th, 2008
i have a nm-hdv in slot one and a vic2-2fxo in the module. this 2811 has four hwic slots - can i put the vic2-2fxo in an hwic?
sh diag
Slot 1:
High Density Voice Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JAE07420BVK
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NM-HDV=WIC Slot 0:
VG - FXO Voice daughter card (2 port)
WIC module not supported/disabled in this slot
Hardware Revision : 5.0
Top Assy. Part Number : 800-21597-01
Board Revision : E0
Fab Version : 04
PCB Serial Number : FOC09301FGD
RMA History : 00
Version Identifier : V
Product (FRU) Number : VIC2-2FXO=
thanks in advance.
Correct Answer by Paolo Bevilacqua about 9 years 1 week ago
That is what I was telling you ... The ISR routers are really made to work this way ...
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 02/18/2008 - 22:43
Yes, but you need the DSP modules on the router mainboard. The smaller is PVDM2-8 and will support 8 voice channels.
jerry.mcrae Tue, 02/19/2008 - 09:24
ok - im configuring this as a 911 line at a remote site. ill dig up DSP's and give it a shot.
thanks for the reply.
jerry.mcrae Tue, 02/19/2008 - 09:42
you said to put the pvdm2 on the motherboard and not on the nm-hdv?
jerry.mcrae Tue, 02/19/2008 - 10:18
i already have dsp on the motherboard.
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8538-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC1144176Z
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-16
Version Identifier : V01
EEPROM format version 4
PVDM Slot 1:
48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Part Number : 73-8540-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC11372FMR
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-48
EEPROM contents (hex):
Correct Answer
Paolo Bevilacqua Wed, 02/20/2008 - 11:19
jerry.mcrae Fri, 02/22/2008 - 09:59
so i ended up removing the nm-hdv from slot 1 in the 2811 and adding the VIC2-2FXO in hwic slot 3 and the router found it - no more errors during a sh diag.
thanks.
