ASA5505 - Can not Communicate between two host from outside to inside
Answered Question
Feb 18th, 2008
Dear all,
I am new for CISCO security devices.
We have purchased a ASA5505 for securing internal nw allowing only specific users to access the DCS server installed at inside NW i.e 192.168.1.1 255.255.255.0
Allowed users are
1. 10.51.161.16 255.255.255.0 which is routed by MSFC card.
2. 10.51.7.121 which is routed by MSFC card.
I have tried a lot. But unable to suceed.
Please Can any one provide me the working configuration ? I am attaching current running configuration and basic topology diagrame.
Pls help me as soon as possible.
Correct Answer by abinjola about 9 years 1 month ago
hold on Dipesh..put the satic back in the configuration you do need static xlate rule from outside to inside
Now I asked for the debug icmp trace when you pinged 192.168.1.2 (DCS server), however I don't see you pinging your DCS in the debugs, I noticed you pinging 192.168.1.1
Initiate a ping to 192.168.1.2 from outside machine and get me the debug output
Also turn on the
logg on
logg buffered 7
and get me the sh logg output
Overall Rating: 4 (1 ratings)
abinjola Mon, 02/18/2008 - 21:29
  • Cisco Employee,
COnfig looks good, is DCS server 192.168.1.2 ?
Is there a return route/DG set on 192.168.1.2 ?
I want you to turn on debug icmp trace on firewall and run pings from outside machine to 192.168.1.2..get me the debugs
Dipesh Patel Tue, 02/19/2008 - 01:05
Debug result
ABB-ASA5505# debug icmp trace
debug icmp trace enabled at level 1
ABB-ASA5505# ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=1536
len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=1792 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=2048 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=2304 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=2560 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=2816 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=3072 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=3328 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=3584 len=32
ICMP echo request from 10.51.7.121 to 192.168.1.1 ID=512 seq=3840 len=32
dongdongliu Mon, 02/18/2008 - 22:14
does the MSFC have the route about DCS server?
which kind of application(tcp & udp) are used in the DCS server?
Dipesh Patel Mon, 02/18/2008 - 22:20
yes,
route is
ip route 192.168.1.0 255.255.255.0 10.51.7.30
Communication of IP - Fully communication between these hosts.
dongdongliu Mon, 02/18/2008 - 22:44
hi Dipesh,
please remove the "static (inside outside)..." and then try again.
Dipesh Patel Mon, 02/18/2008 - 23:05
Dear dongdongliu ,
You mean to say I disable NAT? Without Nating is it works?
I can not ping any host.
But Pkt tracert shows its working.
But without route on MSFC also it shows working.
dongdongliu Mon, 02/18/2008 - 23:13
Deer Dipesh,
I do not think of
"static (inside,outside) 192.168.1.2 192.168.1.2 netmask 255.255.255.255"
is NAT command.
there is not the "NAT" command in the configuration on the ASA
I suggest to add a line:
static (inside,outside) 10.51.7.3X 192.168.1.2
regard
dongdong
adamperrego Tue, 02/19/2008 - 05:17
Yes..Whatever host you are trying to ping or do a 1 to 1 mapping.
Correct Answer
abinjola Tue, 02/19/2008 - 06:04
  • Cisco Employee,
Also turn on the
logg on
logg buffered 7
abinjola Wed, 02/20/2008 - 20:53
  • Cisco Employee,
Is the issue resolved..do let me know plz.?
Dipesh Patel Thu, 02/21/2008 - 01:28
Yes Issue was resolved but one more problem is that :
I can not access telnet or http from outside......
I m trying to accesstelnet or http using IP
10.5.213.22
Working Running Config is life this .....
sh run
: Saved
ASA Version 7.2(2)
hostname ABB-ASA5505
domain-name cisco.com
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 172.5.200.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.5.213.30 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
clock timezone IST 5 30
dns server-group DefaultDNS
access-list inside_access_in extended permit ip host 172.5.200.2 host 10.5.161.16
access-list outside_access_in extended permit ip host 10.5.161.16 host 10.5.213.21
access-list outside_access_in extended permit ip host 10.5.161.16 host 10.5.213.22
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
static (inside,outside) 10.5.213.21 172.5.200.2 netmask 255.255.255.255
static (inside,outside) 10.5.213.22 172.5.200.1 netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.5.213.35 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 172.5.200.2 255.255.255.255 inside
http 10.5.161.16 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 172.5.200.2 255.255.255.255 inside
telnet 10.5.161.16 255.255.255.255 outside
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
ABB-ASA5505#
Pls help
abinjola Tue, 02/26/2008 - 04:58
  • Cisco Employee,
put the command "http 10.5.213.22 255.255.255.255 outside"..see if you can open ASDM (GUI) of the firewall now
Also For your information..we cannot telnet to the firewall from outside (security-level=0) but we can ssh to it from outside
ssh 0 0 outside
crypto key gen rsa mod 1024
see if this helps !
