[RTMT-ALERT] CallProcessingNodeCpuPegging
Feb 18th, 2008
Hi experts,
we've been receiving alot of these high cpu usage. The issue is why are these changing randomly? So we cannot focus on which to attend to! we already restarted the server, but still the same.and the server is not yet crushing which we don't want of course!
Any suggestion?
thanks
Cisco At 14:27:03 on 02/18/2008 on node x.x.x.x.
Processor load over 90 Percent.
okclient (41 percent) uses most of the CPU.
Cisco At 00:06:03 on 02/19/2008 on node x.x.x.x.
java (79 percent) uses most of the CPU.
Cisco At 02:27:44 on 02/19/2008 on node x.x.x.x.
ccm (100 percent) uses most of the CPU.
Cisco At 06:27:43 on 02/19/2008 on node x.x.x.x.
TSC (91 percent) uses most of the CPU.
Cisco At 08:28:00 on 02/19/2008 on node x.x.x.x.
ccm (71 percent) uses most of the CPU.
Cisco At 12:28:24 on 02/19/2008 on node x.x.x.x.
leventmgr (30 percent) uses most of the CPU.
Cisco At 16:28:19 on 02/19/2008 on node x.x.x.x.
TSC (84 percent) uses most of the CPU.
Anonymous (not verified) Fri, 02/22/2008 - 14:04
Restart DBL Layer Monitor service on the publisher.This should take care of the problem . also check the details of this bug :CSCse47327
redrobish Mon, 02/25/2008 - 19:03
thanks rrjoas45.
follow up, is only the CDR affected when we restart this service or anything else is affected?
tnx
redrobish Sun, 03/02/2008 - 21:57
hi rrjoas45,
when i restart the DBL Layer Monitor service, will the Ip Phones be affected? i.e. reboot
tnx
redrobish Mon, 03/03/2008 - 17:28
sorry, the issue was not fixed when the Cisco Database Layer Monitor service was restarted. Any other idea?
not related to bug: CSCse47327
Cisco IOS version:
OS Image: 2000.2.7
OS Service Release: 2000.4.2sr5a
OS Upgrade: 2000.4.2
CM ver: 4.1(3)sr3a
tnx
