Cisco ASDM 5.X/6.X Traffic Usage Graph Window
Answered Question
Feb 18th, 2008
Hi All,
I was wondering if it is possible to change the graphs under "Home" of ASDM. By default ASDM always, shows a graph of the interface 0 (outside interface). I was wondering if I could change that to display traffic usage of another interface (in our case, we do no use outside interface....)....
Thanks.
Correct Answer by ajagadee about 9 years 1 month ago
My understanding is, it is not possible to change the display to another interface because the traffic throughput is for the lowest security interface. In your case, the outside interface, which has the least security level.
In most cases, the outside interface is used and that is what gets displayed in the Home Page. Since, you are not using the outside interface and its in shut down mode, you could change the security level to a lower level compared to the other interface and see if the behavior changes.
http://www.cisco.com/en/US/docs/security/asa/asa80/asdm60/user/guide/intro.html#wp1044598
Name Interface Traffic Usage (Kbps)-Display only. Shows the traffic throughput for the lowest security interface. If you have multiple interfaces at the same level, then ASDM shows the first interface alphabetically. This graph also shows the current throughput by type, input Kbps, and output Kbps.
Arul
** Please rate all helpful posts **
Overall Rating: 4 (1 ratings)
Correct Answer
ajagadee Tue, 02/19/2008 - 15:34
  • Cisco Employee,
Arul
