cpu utilization.
Feb 18th, 2008
Hi Experts,
Can any body clearly explain about cpu utilization that how we will caliculate and what are points we should look when calculating cpu utlization.
Below I am pasting one router cpu utilization.
Router1#sh processes cpu history
3222222222233333333333333333333333333333333333333333333333
1999999999922222222223333311111222222222200000111110000000
100
90
80
70
60
50
40
30 ************************************************************
20 ************************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
3333333333333322322232222322322333333333323333322222222233
0333335313100198187809788099198210344200080000087965013400
100
90
80
70
60
50
40 *
30 #################*###**#######*#######*##*#####**#** ####
20 ############################################################
10 ############################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
3342312112255555555555555565544454555555555555555565544445455555556555
4319572563334566732234543354986816124775321233454224767654824766244584
100
90
80
70 *
60 **** * * * *** * * * *** *** **
50 **####***######**********######*########*********############
40 * * *############################################################
30 #**** #############################################################
20 ###********#############################################################
10 #####****###############################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
Naidu.
aijaz802 Mon, 02/18/2008 - 22:51
  • Bronze, 100 points or more
Hi Naidu,
I'm explaining the first graph details..which is last 60 sec history...
Y-axis is for CPU utlization..
X-axis is the time in seconds...which is you can read the columns as 0sec,5 sec, 10sec,15 sec...pls note the values are in vertical for 10 sec its 1 and below is 0...for 35th sec..its 3 and below is 5..
Please check the values again the switch/router..as the alignment of values posted here is gone.
The top two columns denote the maximum cpu utlized...in seconds graph..its 31%...read vertically..
in 60 minutes its 30%, in 72 hrs..its 34%..
I hope u understood it...you can go thru the following link for detailed explanation.
http://www.cisco.com/warp/public/63/showproc_cpu.html
Please rate if it helps..
*aijaz*
