ramboza2006 Tue, 02/19/2008 - 02:16
which table in callmanager database contains users&passwords entries?
Jaime Valencia Tue, 02/19/2008 - 09:13
  • Cisco Employee,
  • Hall of Fame,
    2011
there is no default password, if you're using DCD when you created each user the pwd was a required field you needed to enter
if you're integrated with AD then they're using the credentials from the directory and in order to change them you need to log into AD
the users are not in the CUCM DB, they're in the directory to which you're integrated
