Load Balancing*********************************************
Feb 19th, 2008
I have two 512 kbps of link from same ISP and both link were terminated on same router. I have different LAN/WAN pool for both ISP. M using nat on same router but want to do load sharing on both link.How it is possible.
Pls help me out,
Thanks ..
shivlu jain Tue, 02/19/2008 - 03:53
actually its not a good idea to take the two links from the same isp on same router becasu it wonot give you backup. For load sharing you can use the multilik but multilink has many advantages and disadvantes.
So please read carefully before impementing this.
Another option is that you can use the policy based routing.
Seconf option is not a good solution.
regards
shivlu
