ACE + AVS integration
Feb 19th, 2008
Hi I have ACE(6504-E) module configured for multiple context . Now i want to connect two AVS 3120 for webcaching ( i want to configure AVS as Failover ). In this scenario how i can connect my AVS in ACE Bundle .
Your valueble suggestions are appreciated !!
aslamta
jsivulka Mon, 02/25/2008 - 07:24
The AVS 3180A supports the ACE 4710 appliances for AppScope reporting only. The AVS 3180A does not provide configuration management for the ACE 4710 appliances. Configuration management for the ACE 4710 is supported using the embedded device manager or by using the Cisco Application Networking Manager (ANM) software.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/avs/v51/release/note/AVS51RN.html
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/administration/guide
