ccm 4.1.3 droped calls
Feb 19th, 2008
Hi, we use ccm 4.1.3 and it periodically drop all calls. Where are lot of messages (in event viewer) like Cisco CallManager stops (start) handling calls for the indicated H323 device due to route loop over H323 Trunk. But calls drops not with every this message. What reason might be with dropped calls ?
w422266 Tue, 02/19/2008 - 04:45
Fault on the pri/bri are there any errors when you look at the e1 controllers?
