2801 Router with 2 x ADSL Connections
I have a Cisco 2801 running advanced ip services tht already has a single DSL connection to the internet that is configured for VPN access. A DMZ has been configured to a single 2960 switch with a webmail serevr. All is working perfectly well .....
I now have a requirement to add another DSL connection that is to be kept seperate from the existing DSL connection and a ISA/Proxy server to be used with it to filter/monitor web traffic.
Can someone advise if this is possible on my single 2801 router and perhaps post a sample config ??
Stuart
paolo bevilacqua Tue, 02/19/2008 - 05:18
  • Hall of Fame,
    Founding Member
Yes is't possible, by use of route maps in nat statements. Basically you define which inside adressess do use which interface.
