Cat3560: More than 128 SPT Instances?
Answered Question
Feb 19th, 2008
Hi everybody
In a secured VTP, we have many but small VLANS. But now we are hit by a Hardware Constraint: Our Switches (c3560G) can't handle more than 128 Spanning-Tree Instances. Reducing the Vlans is no option for our Security Audit, per-vlan-disabling of SPT (rstp to be exact) is no option for us either.
Is there any way to enhance the VLAN-Capactity of c3560-Switches (e.g. different IOS), or do we really have to either buy new Hardware or split the VTP into multiple Domains? If so - is there anywhere a comparison table, how many STP-Instances which Cisco-Switch can manage?
Currently used Hardware: WS-C3560G-48TS
Currently used Software: c3560-ipservicesk9-mz.122-25.SEE2.bin
Thx in advance and sorry for the bad english
Greetings from Bern, Switzerland
Stefan Mueller
Correct Answer by Lars Persson about 9 years 5 months ago
You can go for MSTP (Multiple spanning tree) which gives you the possibility to run several VLANs in the same spanning-tree instance. MSTP also run rapid spanning tree giving you the same convergence time as RSTP.
regs /Lars
Overall Rating: 3 (1 ratings)
Correct Answer
Lars Persson Tue, 02/19/2008 - 05:30
regs /Lars
mullzkBern_2 Tue, 02/19/2008 - 10:23
Thanks a lot, somehow I thought RSTP would prohibit the use of MSTP. Now I have something to learn for the next few days :)
Still - Is there any place where Capabilities and Limitations of Cisco LAN Switches are directly compared, e.g. in one giant table? Does anything like this exist for IOS-Releases exist as well?
