Custom Application to set/get TACACS+ information a User
Feb 19th, 2008
I have to develop a custom application that sets/gets TACACS+ information for a particular user profile.
I was able to set values in "TACACS+ Enable Control" form and "TACACS+ Enable Password" form using action code 105.
But I am not able to set "Use separate password" flag and separate password in "TACACS+ Enable Password" form,
and TACACS+ Outbound Password . Can somebody give me the actioncodes and show how the entries in accountactions.csv file
will look for the mentioned operations that is:
1) to update TACACS+ outbound password, and
2) to set "Use separate password" flag and separate password in "TACACS+ Enable Password" form
My next question would be:
How do we retrive TACACS+ outbound password and attribute values in "TACACS+ Enable Password" form dump.txt
I was able to retrieve values for attributes in TACACS+ Enable Password" form
Following is a sample entry in dump.txt for these attributes:
App01 enable_passwd ESTRING 0x0018 6a 35 9b 76 ce c3 81 9c 6d 1c d5 41 06 1a 4e 07 92 8d 50 06 de d4 2a 89
App01 max_priv STRING 0,3 (used for attributes in TACACS+ Enable Password" form)
App01 max_priv_LENGTH INTEGER 3
I also checked the link:http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/user/guide/ag.html
But I did not find satisfactory information.
Please reply ASAP, your help will be most appreciated.
Ravi
jhillend Tue, 02/19/2008 - 09:47
  • Bronze, 100 points or more
1) Use code 104
2) Use code 102; this sets the flag with the ENABLE_LEVEL_STATIC flag set
Do not use the dump.txt for retrieving values. The format of this file is not published.
All passwords are encrypted.
sravit123 Thu, 02/21/2008 - 04:31
Could you give examples for cases 1) and 2).
Could you provide an alternate way to retrieve values especially TACACS+ Enable Password attributes. I am lost here.
Awaiting your reply,
Ravi.
