CAN'T COMMUNICATION BETWEEN IPSEC VPN CLIENT AND SSL VPN CLIENT
Feb 19th, 2008
CAN'T COMMUNICATION BETWEEN IPSEC VPN CLIENT AND SSL VPN CLIENT,ipsec and ssl user same ip pool,ipsec to ipsec is normal,ssl to ssl is normal.
guoqiang.li Mon, 02/25/2008 - 17:01
Hi,Pengke11,can you tell me the exact URL link?
thanks a million。
guoqiang.li Tue, 04/15/2008 - 23:30
disable such scanning,can you tell me the detail cfg from the link you given me.
