7206VXR out of band management via Auxiliary
Feb 19th, 2008
does anybody know which is the cable do I have to use to connect the aux port of my 7206 and the db9 female connector of the modem ?
I didn't order the kit ACS-2500ASYN and to be honest I don't know if in this kit there is the cable I need...
Basically I need to connect AUX rj45 to Modem db9 female..
Tks
Ric
James Lasky Tue, 02/26/2008 - 00:02
thanks but I know that cable.
My problem is that the female db9 pinout connector is on the modem as well...
console cable
rj45 <---> db9 female
modem has db9 female connector
Any other idea for the db9 male connector ?
Tks
Ric
