Unity Alerting
Feb 19th, 2008
Unity 5.x in Failover Configuration
I've configured EMS for all Unity alerts however I also want an alert in the event of a database synchronization error. Can anyone tell me which alert should be enabled to support this, or if it's already within one of the "AllUnity" alerts?
Thanks in advance,
Brian
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 02/19/2008 - 09:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Brian,
Hope all is well with you! With the "AllUnity" Alerts setup you should be good to go. The doc below lists the services that are covered including your query;
AvCsNodeMgr
The Node Manager service provides the core services for failover. It runs on both the primary and secondary servers, and is responsible for monitoring the status of the servers. It is also responsible for file replication between the servers.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/404/troubleshooting/guide/ex/tsgappa.html
Hope this helps!
Rob
Brian Carscadden Tue, 02/19/2008 - 12:14
Hi Rob,
All is well. Thanks for the quick response. This is exactly what I was looking for. 5 Stars!
Brian
