help with Identifying FXO port on outgoing call- CCME
Feb 19th, 2008
I have 4 fxo ports and 4 dial peers
callers dial 0.T on outgoing calls and i use preference command to send calls out over the 4 Analogue lines.
I want to display a line number on the phone to help me find a cut off problem
something line "line1" "line2" etc.
Does anyone know how i might do this?
regards
colin
douhanm Sat, 02/23/2008 - 08:35
you cant but you can add one more dial-peer per port with diff prefix 1.T 2.T etc and then call each one to find the issue
ReadersUK Mon, 02/25/2008 - 02:39
thanks for the reply, i have already done that. I need the help from locals on site who are logging the cut off problem for me.
regards
colin
