cue aa unknown number
Answered Question
Feb 19th, 2008
is it possible to test the aa from an extension?
the def aa was enabled but it shows unknown number when i dial the number from one of the extension.
Correct Answer by pcameron about 9 years 1 month ago
The CUE AA receives call from the CME via a SIP dial peer. So as long as you have a dial peer that points to the IP address of the CUE , it should be reachable from POTS legs , IP legs (if you have 'voice service voip'/'allow connections ...' configured) and ephone call legs.
The dial peer should be something like this -
dial-peer voice 10 voip
description - calls to AA application on the CUE
destination-pattern 5000
session target ipv4:10.1.1.1 <---Ip address of CUE
session protocol sipv2
codec g711ulaw
dtmf-relay sip-notify
The CUE will need to have a relevant config as well - you can enable the aa application from the GUI or from the CUE cli. All it needs is a trigger number that matches what you have configured under the SIP dial peer on the CME.
Otherwise paste the configs of the CME and CUE here so we can have a look at it.
Overall Rating: 5 (1 ratings)
Correct Answer
pcameron Tue, 02/19/2008 - 13:46
  • Cisco Employee,
codec g711ulaw
