Large file transfer crashes network
Feb 19th, 2008
We have a Cisco network with two sites joined by a gigaman leased line. Whenever we try to transfer a large file (18 gigabytes) from one site to the other, many of the switches on both sites get such a backlog of traffic that the entire network is brought to a standstill. Transferring the same file to a computer on the same site does not cause a problem.
I realize this is a very general description of the problem, but can you suggest in general what I should be looking for to solve it? I'll be glad to supply more detailed info if requested. Thanks. -G.
This discussion is closely related to something I am trying to accomplish as well.
My company has a 1721 router that links us to our ISP T1. The next hop up is an IDS box and then our PIX firewall.
Frequently when I download large files, our entire bandwidth (1.5Mbps) is fully utilized.
Is there a simple way to configure the 1721 to only allow 384kbps per connection?
All connections will appear as coming from our firewall, so I don't really have subnets, a VLAN, or group class upon which to differentiate. I'm hoping there is simply a global config that will limit any individual connection.
Please advise + Thanks!
Tom Watts
