robiadams Tue, 02/19/2008 - 14:24
These are tracked by the phone device, in the local memory, not thru the url.
Mike-1985 Tue, 02/19/2008 - 23:29
Yes that is true...
The Cisco IP Phone places those menuItems ontop of the directories-url menu. The only thing you could try is to enter a invalid url as directory-url. The phone will then display a 404 error and probably won't show the missed calls etc.
Give it a try ;)
javinunorosal Wed, 02/20/2008 - 00:24
Unfortunately it still shows missed/received/placed calls.
MooneyN Tue, 02/26/2008 - 19:56
Did you find an answer to this?
We need to setup shared phones that will not log missed/recieved/placed calls or have access to the directory. The 7902 would be a good fit but it's not for sale anymore.
Can the clearing of the lists be automated somehow? I know that they can be cleared on EM logout but we don't use EM.
Any suggestions?
Mike-1985 Tue, 02/26/2008 - 23:59
see:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/6_0/english/programming/guide/xsi60uri.html#wp1033340
Init
The Init URI allows an application to initialize a feature or data with the argument that is passed with the URI.
URI Format:
Init:o
Where
o = the Object name.
Valid object name:
CallHistory-When the phone encounters an Init:CallHistory URI, it clears the internal call history logs that are stored in the phone. This action initializes Missed Calls, Received Calls, and Placed Calls.
Services-When the phone encounters an Init:Services URI, it closes the Services application. If Services is not currently open, it has no effect.
Messages-When the phone encounters an Init:Messages URI, it closes the Messages application. If Messages is not currently open, it has no effect.
Directories-When the phone encounters an Init:Directories URI, it closes the Directories application. If Directories is not currently open, it has no effect.
So you could create a scriptpage that will send an "Init:CallHistory" when pushing the directories button.
javinunorosal Wed, 02/27/2008 - 00:07
Not yet for log calls. I'm still working on it. I'll tell when I find it... if I do.
If you want to block access to the directory the directory URL in CCM should be changed to a non existing one (http://0 for example) or to a URL that shows an empty menu:
Sin directorios
By the way missed/... calls are still shown.
Hope this helps.
javinunorosal Wed, 02/27/2008 - 08:49
It doesn't show the "Corporate Directory" but it shows missed/placed/... calls.
The goal is not to show call history at all, ideally without having do clear it.
Nevertheless thanks for the ideas
