Cisco Security Manager deploymnt failing
Feb 19th, 2008
I am using CSM 3.1.1 SP2 to deploy policies to routers. All of the deployment is successful except fo one router 2811 running 12.4 11T. The deployment fails with the following description:
failed to parse response from device. Cause: Upload configurationfailed since the CT response from device 10.255.0.34 is malformed. Please contact Cisco TAC and restore the device.
JDOM exception while parsing XML input stream.
I deleted and readded the router without any luck. Any input on this would be greatlyappreciated.
