Creating L2TP tunnel
Answered Question
Feb 19th, 2008
Is there a way to create an l2tp tunnel between two routers, without using encryption or vpn? I just need to extend a layer 2 network for multicast traffic. thanks.
Correct Answer by shivlu jain about 9 years 2 months ago
Grimes
You can do this with the help of PSEUDOWIRE and XCONNECT
Router# pseudowire-class abc
Router(config-pw)# encapsulation l2tpv3
Router(config-pw)# ip local interface loopback 0
int fa0/0.10
encapsulation dot1q 10
Router(config-if)# xconnect peer-router-id vc-id encapsulation l2tpv3 pseudowire-class abc
regards
shivlu
Overall Rating: 5 (1 ratings)
Correct Answer
shivlu jain Tue, 02/19/2008 - 10:29
  • Silver, 250 points or more
Grimes
int fa0/0.10
regards
shivlu
