"ip inspect tcp max-incomplete host" command parameters
Answered Question
Feb 19th, 2008
Hi all,
I have a 7200 router with IOS version 12.3(3)B1 and I am able to configure a limit of 500 for the "ip inspect tcp max-incomplete host" command:
ip inspect tcp max-incomplete host 500 block-time 0
I am migrating to a 7600 with version 12.2(18)SXF but I am not able to configure the limit of 500 as in the 7200. I checked the documentation and the limit is 250, is there a way to increase this value to 500 for the 7600?
Regards.
Correct Answer by ajagadee about 9 years 1 week ago
Unfortunately, there is no way to increase this value to 500. I checked both 12.2(18)SXF and 12.2(33)SRB1 and they both have a limit of 250.
Arul
** Please rate all helpful posts **
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Tue, 02/19/2008 - 15:18
Arul
