Cisco 1841 - Cisco 1841 Site-to-Site VPN - adding subnets
Hi all. I have a pair of Cisco 1841's running a site-to-site VPN between siteA and siteB with 192.168.30.0/255.255.255.0 and 192.168.16.0/255.255.252.0 respectively. All works fine between these two subnets.
I am trying to add an additional subnet at siteB, so using SDM, I added the subnet to the IPSec rules on each of the 1841's.....but siteA cannot see the devices on the new subnet at siteB and the device is routing the packets to the internet.
Any help would be greatly appreciated.
Richard Burts Tue, 02/19/2008 - 09:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
David
You gave us information to work with about the original subnets but did not provide that detail about the subnet that you are adding. Can you give us that subnet?
The obvious assumption about your problem is that somehow SDM did not add the right subnet or did not add it to the right access list. Can you provide the running config from both of the routers? This would help us to identify the problem.
Rick
