Information Request about Unity Connections 2.0 Installation with CM 6.1 cl
Feb 19th, 2008
I get the impression from the common OS platform Administration web pages that a Unity Connection 2.0 server should not be installed as the "first server in the cluster" if it is going to integrate with an existing 6.1 CM cluster. Is there a single "cluster" for CM and Unity Connections, or is the first Connections box also install as a "Primary" in its own cluster? Have I made this question confusing enough?
