Blank Device Names in CiscoWorks Archive Management - how to fix it?
Answered Question
Feb 19th, 2008
I have CiscoWorks 4.0.4. When I go into Archive management and view the failures, I see entries with no device name. Obviously, I will have problems fixing the errors if there is no device name.
Anyone know how to fix this issue?
Thanks!
Correct Answer by Joe Clarke about 9 years 3 months ago
This was a problem in the release of RME you are currently using. It has since been fixed, but removing those old entries is not trivial. You can either ignore them, or open a TAC service request, and they can walk you through the steps to purge the entries from the database. In the meantime, though, you should consider upgrading to LMS 2.6.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 02/19/2008 - 12:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
cybrsage Tue, 02/19/2008 - 12:29
Thank you very much, I suspected such would be the case.
I have been in IT long enough to simply ignore the items which really do not matter yet are VERY hard to fix. It appears this is one of those times.
