Cut-Though, Fragment Free and Store Forward HELP!!!!
Charlie Mayes
I am in the CCNA course and am wondering how to change between the 3 modes above. I have a 2950 and a 2960G switch. I have not seen anything in the book a about this. Is this a CCNP function?
8 Replies 8
Richard Burts
Charlie
Cut through and fragment free forwarding are very old concepts. I would hope that there is not anything in either the CCNA or the CCNP that deals with these.
Rick
Rick
In the book they keep talking about it but, they never show how to enable or disable either one of them. Do you know how?
You can't as it is hardware specific so it is not configurable by the user. The majority of switches are store and forward.
Jon
Charlie
I am surprised (and disappointed) that the book keeps talking about it. What book is this? And when was it published?
Most of the switches just did one or the other switching mode. There was a switch or two that had an adaptive mechanism and if the error rate was low it operated in fragment free and if the error rate increased it would go to store and forward. It was a long time ago and I do not remember the specifics of how it was controlled.
Rick
Rick
ISBN 1-58713-170-6
CISCO ACADEMY CCNA3 TEXTBOOK
As Rick says this does not have particular reference these days. However i think the key thing is that you understand the differences between them.
I wouldn't worry about how to change them on particular switches as you can't.
Jon
You guys have been so helpful. This will help me move forward in life on taking this test. Thanks.
No problem. Best of luck with your test.
