WLC4404
Feb 19th, 2008
I have serveral WLC4404 configured in a Mobility Group. Is there any way to reduce the time it takes to roam between them ?
Scott Fella Tue, 02/19/2008 - 18:31
Try to setup the access points on the same controller to prevent too much inner controller roaming. For example.... if you have 2 4404-100 and you have a max 100 ap's, what you can do is either have all the ap's on WLC1 and use WLC2 as a backup. Another way is to separate the ap's to WLC by floor. Floor 1-3 on WLC1 and floor 4-6 on WLC2. The roaming should be fast anyways, but as long you try to keep the user on a certain WLC then you wouldn't have to worry about the roaming between WLC's. Hope this makes sense.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
