CME files on Flash: with IOS on Slot0:
Feb 19th, 2008
I have a 64 meg flash and 64 meg slot0: Can I place IOS on one and CME files on the other and make CME work? If so, what else needs to be done?
Thanks!!
Gary
This isn't something that I've done but it should be possible.
I would guess that you will not be able to create directories on the Compact flash within Slot0.
I would imagine that the CME files configured like this example.
tftp-server slot0:P00308000500.loads
tftp-server slot0:P00308000500.sb2
tftp-server slot0:P00308000500.sbn
tftp-server slot0:P00308000500.bin
Good luck.
Cheers,
Mike.
