02-19-2008 04:50 PM - edited 03-11-2019 05:05 AM
I'm trying to set up a remote VPN on the ASA. I've simply used the wizard on the asdm because I'm new to this. I can connect to the VPN fine, but once connected I cannot access anything on the internal network, nor can I get out the internet.
I'm using an IP pool of 10.39.230.50-100. The internal network that I want to access is across another router connected to the inside interface, 10.39.1.0. 10.39.239.3 is the router. (it has a subinterface of 10.39.230.3 as well)
It seems like it might be a NAT problem but I can't figure it out. Any ideas?
Solved! Go to Solution.
02-19-2008 08:17 PM
Hi Nathan
Identify subnets individually for routes as much as possible so remove the following route
no inside 10.0.0.0 255.0.0.0 10.39.239.3 1
and add routes to subnets individually like
inside 10.39.1.0 255.255.255.0 10.39.239.3 1
Most important, add the return trip traffic route for your VPN clients in router(the router with 10.39.239.3 IP)! But since (it has a subinterface of 10.39.230.3 as well) is correct, it assumes 10.39.230.0 is a connected route, so you should use a VPN IP range that does not exist in router or firewall. For ex
ip local pool fds_pool 192.168.120.1-192.168.120.126 mask 255.255.255.128
tunnel-group fds general-attributes
no address-pool fdspool
address-pool fds_pool
then
no access-list inside_nat0_outbound_1 extended permit ip 10.39.1.0 255.255.255.0 10.39.230.0 255.255.255.128
access-list inside_nat0_outbound_1 extended permit ip 10.39.1.0 255.255.255.0 192.168.120.0 255.255.255.128
add the following acl
access-list inside_access_in permit 10.39.1.0 255.255.255.0 192.168.120.0 255.255.255.128
Add the following route in router
ip route 192.168.120.0 255.255.255.128 10.39.239.20
Finally a split-tunnel
access-list split_t permit ip 10.39.1.0 255.255.255.0 192.168.1.120 255.255.255.128
group-policy fds attributes
split-tunnel-policy tunnelall
split-tunnel-network list split_t
02-19-2008 06:53 PM
Hi, Nathan
it seems like you access internal server from inside interface, so the traffic is input and output at same interface(inside ifterface), doesn`t it?
regard
dongdong
02-19-2008 08:17 PM
Hi Nathan
then
02-20-2008 01:44 PM
Thanks for the response! I've made the changes you suggested, but no split tunneling because we aren't going to be using it. It's still not working correctly. I can't get internet when connected to the VPN.
access-list inside_access_in permit 10.39.0.0/16 255.255.255.0 192.168.20.0 255.255.255.0
I changed to the above for test purposes. I can talk to the network connected to the interface on the ASA (10.39.239.0) but not to the remote segment (10.39.1.0). I've added an ip route 192.168.20.0 255.255.255.0 10.39.239.0 to the router. Any more ideas?
02-20-2008 07:33 AM
Try a tunneled gateway.
route inside 0.0.0.0 0.0.0.0 10.39.239.3 tunneled
Also make sure you have a route on the inside router for the VPN IP pool.
02-21-2008 04:23 PM
Nathan,
Please post your current running config after modifications
02-21-2008 05:04 PM
Got it working now. Turns out that I needed a route back on the router at the other office. Thanks guys!
