Please define
Feb 19th, 2008
  • Bronze, 100 points or more
Please define the following commands for me and why they are used. I cannot find definitions for them anywhere, and I don't want to wait another week to ask my instructor:
* ip classless
* ip subnet-zero
* no ip domain-lookup
All of these commands are entered at the config prompt.
lamav Tue, 02/19/2008 - 17:41
  • Blue, 1500 points or more
ip subnet zero enables the use of subnet zero for interface addresses and routing updates. Subnetting with a subnet address of zero is illegal and strongly discouraged (as stated in RFC 791) because of the confusion that can arise between a network and a subnet that have the same addresses. For example, if network 131.108.0.0 is subnetted as 255.255.255.0, subnet zero would be written as 131.108.0.0-which is identical to the network address.
no ip domain lookup disables DNS lookups (hostname to ip address mapping) for host names. For example, if you enter "ping http://www.yahoo.com" at the hostname prompt, the PING test will not be executed successfully because the router cannot do the ip address mapping for the FQDN. The same is true if a network administrator wants to telnet from one router to another by using the router's hostname, ie "telnet hostname2."
ip classless enables classless routing behavior, ie. CIDR, VLSM.
Please rate this post if it was helpful..
Victor
