privilege configuration
acbenny
enable secret 5 enable
username admin privilege 15 password 0 admin
username guest privilege 5 password 0 guest
username 123 password 123
privilege exec level 15 enable
privilege exec level 5 reload
privilege exec level 5 show tech-support
privilege exec level 5 show startup-config
privilege exec level 5 show running-config
line con 0
password console
login local
transport input none
line vty 0 4
password telnet
login local
I can't use 123 username to login to privilege mode, is it correct ?
Username: 123
Password:
Router>e?
exit
When I use guest account to login and issue " show running-config" Just show little config. Why not the whole config ?
Username: guest
Password:
Router#show running-config
Building configuration...
Current configuration : 51 bytes
boot-start-marker
boot-end-marker
end
5 Replies 5
guruprasadr
Level 7
Level 7
HI, [pls rate if helps]
Username: 123
>> It is not associated with any privilege levels. So, enable access will be restricted for the user.
Username: guest
password:
>> Issue the below command:
Router#show prvilege
>> Verify the Output
!! Note the default privilege level for enable commmand is level 15
PLS RATE if HELPS
Best Regards,
Guru Prasad R
dongdongliu
1/ I am not sure why user 123 can not login eanble mode.
2/ user guest only can watch configuration that guest can config, because guest do not have enough privilege to config sth, so guest look at nothing.
regards
dongdong
ajagadee
This behavior is by design. Please refer the below URL for details:
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00800949d5.shtml
Also, you may want to look at Role-Based CLI Access as a possible solution.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_7/gtclivws.htm
Arul
** Please rate all helpful posts **
dongdongliu
hi all
i know,
with "username 123 password 123", user 123 only have a default privilege 1 and login "enable mode" need 15 privilege on that router, so...
thanks for your link,i am happy to rate...
dongdong
