Two TKIP Michael MIC failures were detected within 0 seconds on Dot11Radio0
Feb 19th, 2008
Hi NetPro,
anyone who has encountered or seen this before ?
Error Msg - Two TKIP Michael MIC failures were detected within 0 seconds on Dot11Radio0 interface. The interface will be put on MIC failure hold state for next 60 seconds.
Warning Msg - Received TKIP Michael MIC failure report from the station 0019.d2be.fd3d on the packet (TSC=0x0) encrypted and protected by group key.
Warning Msg - Received TKIP Michael MIC failure report from the station 001b.7706.c63f on the packet (TSC=0x0) encrypted and protected by group key.
your reply will be higly appreciated.
thanks.
Jack
Overall Rating: 3.5 (2 ratings)
Scott Fella Tue, 02/19/2008 - 19:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You can find an explanation here:
http://cisco.com/en/US/docs/ios/12_4t/wlan/configuration/guide/wlcgerr.html
Error Message
DOT11-TKIP_MIC_FAILURE_REPEATED: Two TKIP Michael MIC failures were detected
within [number] seconds on [interface] interface. The interface will be put on MIC
failure hold state for next [number] seconds
Explanation Because MIC failures usually indicate an active attack on your network, the interface will be put on hold for the configured time. During this hold time, stations using TKIP ciphers are disassociated and cannot reassociate until the hold time ends. At the end of the hold time, the interface operates normally.
Recommended Action Michael MIC failures usually indicate an active attack on your network. Search for and remove potential rogue devices from your wireless LAN. If this is a false alarm and the interface should not be on hold this long, use the countermeasure tkip hold-time command to adjust the hold time.
ney25 Tue, 02/19/2008 - 20:08
Hi Fella,
thanks for your information, but would you mind to show / guide me how to do ?
thanks.
regards,
Jack
Scott Fella Wed, 02/20/2008 - 19:31
  • Hall of Fame,
    2017 Wireless
Have you tried to use this command: countermeasure tkip hold-time????
Use the countermeasure tkip hold-time configuration interface command to configure a TKIP MIC failure holdtime. If the access point detects two MIC failures within 60 seconds, it blocks all the TKIP clients on that interface for the holdtime period.
countermeasure tkip hold-time seconds
Syntax Description
seconds
Specifies the length of the TKIP holdtime in seconds (if the holdtime is 0, TKIP MIC failure hold is disabled)
Defaults
TKIP holdtime is enabled by default, and the default holdtime is 60 seconds.
Command Modes
Configuration interface
stanleyworks Fri, 02/06/2009 - 07:20
Fella5,
is TKIP MIC hold is disabled or it does shutdown and come right back up....
I do see my user get disconnect and reconnect... and error message is MIC failure (WPA2/AES) user
