Vlan Interface Stays Admin Down
Feb 19th, 2008
I was not able to "un shut" Interface Vlan 10. Switch took "no shut" with no complains but interface stays Admin Down. This is on a WS-C3524-XL-EN Version 12.0(5.2)XU.
Below is the config.
SFS-EMC-Switch#sho run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SFS-EMC-Switch
enable secret xxx
clock timezone PST -8
ip subnet-zero
interface FastEthernet0/1
description Trunk to 6509
switchport access vlan 10
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 61
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
switchport access vlan 62
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
no ip directed-broadcast
no ip route-cache
interface VLAN10
ip address 172.16.64.40 255.255.192.0
no ip route-cache
shutdown
line con 0
transport input none
stopbits 1
line vty 0 4
line vty 5 15
login
end
everestm Tue, 02/19/2008 - 20:46
Have you tried doing a 'shut' on int vlan 1 first?
Everest
nguyenvinnie Tue, 02/19/2008 - 21:05
No, I did not. Will try this when I come to work in the morning. Thanks
shivlu jain Tue, 02/19/2008 - 20:48
  • Silver, 250 points or more
Vlan interface shows down only that time when you were not entered the vlan command manually. So do the given below in your switch
router(config)#vlan 10
router(config-vlan)#exit
after that your vlan interface comes up.
Simply create a vlan
regards
shivlu
shivlu jain Wed, 02/20/2008 - 00:04
Is your problem solved by creating a vlan or not.
regards
shivlu
a.cruea1980 Wed, 02/20/2008 - 05:06
  • Bronze, 100 points or more
You can also assign VLAN 10 a loopback and "no shut" the loopback interface. That will bring up your VLAN.
Also, since your port is in trunk mode, I'm not sure "switchport access" really does much. I could be quite wrong on that, though.
nguyenvinnie Wed, 02/20/2008 - 08:50
Shivlu, problem solved when I shut down Vlan1.
a.cruea1980, I think you're right on "switchport access", it doesn't do much since it's in trunk mode already.
I have one more question, there're 2 vlans (61,62) in this switch, these 2 vlans info will it automatically passing throug the trunk? In another word, will I be able to access to these 2 vlans from remote.
The reason I ask, because On CatOS these 2 vlans have to be allowed thru the trunk by configuration.
everestm Wed, 02/20/2008 - 11:47
All configured VLans will go through the trunk by default. You can limit them by manually defining allowed vlans on the trunk interface using the "switchport trunk allowed vlan x,x,x" command.
Hope this helps!
Everest
Edison Ortiz Wed, 02/20/2008 - 12:12
  • Hall of Fame,
    Founding Member
3524 is a layer2 switch and only allows you to have one management interface up/up at the same time. You need to choose either Vlan1 or Vlan10 to be your management Vlan.
__
Edison.
