CCM Partition
What is CCM Partition and where do we configure it?
I understand that during installation CCM creates two partition one Active and other Inactive.This helps us to upgrade the CCM after installation and revert back to the old incase if there comes some issues post installation.
May i know, what are the contents/Components of CCM partition?
Jaime Valencia Wed, 02/20/2008 - 08:22
  • Cisco Employee,
  • Hall of Fame,
    2011
the CCM partitions are logical drives within a single HDD model.
If you've ever used Linux before you know that linux requires several partitions to work. you can even do this in windows environment, you can take a 250 GB HDD and partition it to make it appear like 2 x 125 GB HDDs
each partitions contain ALL the information from the linux OS, the CUCM files, services, etc. All you had in a CCM 4.x install should be in there, maybe not the same services or the same filenames but it's all in there.
linux core files, tomcat root and web pages, licenses, the informix DB, etc. all is in each partition
well, for the 1st install it's only in the active partition but when you apply an SR or ES you do the swapping since all that takes place in the inactive partition.
about where to configure it you do not get the option to configure it. the bootable disk detects the HW you have and during the install formats the HDD and creates the partitions based on the HDD space you have (again, this can be done manually in regular linux or windows before even installing anything)
Jaime Valencia Thu, 02/21/2008 - 07:51
  • Cisco Employee,
  • Hall of Fame,
    2011
=), sorry, maybe i'm just used to this
when we talk about CUCM versions we usually mean
SR = Service Release
ES = Engineering Special
but in other context they can be what you typed
