Jaime Valencia Wed, 02/20/2008 - 10:30
  • Cisco Employee,
  • Hall of Fame,
    2011
if you mean that you want to collect the traces using RTMT that is for 5.x and 6.x, in 4.x you need to use the trace gathering tool or manually pull them from program files/cisco/trace
Set Up Cisco CallManager Traces for Cisco Technical Support
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
