CTIOS Session Objcet Question
Feb 19th, 2008
Does anyone know if you can use the SDK to moniter any agent currently logged into CTIOS? In my testing I only be able to moniter things directly in my app and envioronment. I wantintercept monitor CTIOS events for every other agent that is already connect via say CTIOS Desktop.
lpezj Wed, 02/20/2008 - 00:16
There is an example in 'Program Files\Cisco Systems\CTIOS Client\CTIOS Tools\AllAgentsMonitor' that it allows to monitor all the agents, selecting one.
Hope this helps,
Juan Luis
Chad Stachowicz Wed, 02/20/2008 - 00:39
Does anyone happen to have the Screenpop Sample from CTIOS 4.6. I code in C++ and this java is too hard for me to decipher, but thanks for the help Juan :)
rbua Wed, 02/20/2008 - 06:52
Hi Chad,
4.6 is mostly no longer supported, 3 or 4 yers old why are you still looking to code in that old release?
I would seriously consider a release upgrade, there are tons of bugs you might get into.
Chad Stachowicz Wed, 02/20/2008 - 11:45
Because the C++ Sample was taken out of the CTIOS 7, and I just want the sample, disc is too old for me to get. I am trying to find a way to put the Session Object into a monitor mode, rather then a login mode so that I can moniter every event going through the CTIOS Server, not just the ones coming from my application..
rbua Wed, 02/20/2008 - 12:12
HI Chad,
not that they are easy to get or shared anymore apart for a Dev Support contract owner, but if you like C or C++ as a programming language to perform what you look for, C API to interconnect to CTI Server in Bridge Mode should still be available and work also with newer releases and provide what you need.
I would recommend getting a Dev Support Contract and review in detail with the Custom Engineer your scenario and your available options based on it.
